Power-Line
Power-Line
Features
• Thermoset resin plug cases with floating pins for superior electrical contact
• 4mm2 copper conductors with individual dielectric insulation
• Rubber outer sheath for high levels of inherent mechanical damping
• 2m length for added flexibility with installations
Technology & Craft
The Power-Line mains plug is designed with a thermoset resin case and floating pins that align to provide better contact with socket connections. The stripped cable ends are secured with specially profiled clamp screws, and a die-cast component ensures that the cable is decoupled and clamped.
The Power-Line cable is custom manufactured with 4mm² cross section copper conductors, individual dielectric insulation, and a rubber outer layer that provides high levels of mechanical damping and stiffness for easy installation.
The Power-Line also features an IEC inlet plug that continues the decoupling and electrical continuity themes of the mains plug. It has floating contacts, combined decoupling and clamping, double wiper contacts, and eddy current suppression for better performance.
Similar products
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
