NSS 333
Book a listening session
Simplicity of streaming
Streaming your music has never been easier with the NSS 333. Allowing you to play the latest streaming platforms, such as Spotify Connect, Apple Music, TIDAL, and Qobuz, as well as listen to your favourite internet radio stations. It is equipped with integrated technology such as AirPlay2, Chromecast, UPnP™, Roon Ready, and Bluetooth® AptX technologies, making it simple and secure to stream content from your smartphone or tablet.
Focal & Naim App
With the Focal & Naim app, controlling your NSS 333 is easy. Connect to your playlists or stream content from your smartphone or tablet. The app provides a new way to browse and control your music, while the integrated online music database, Rovi, offers detailed information such as biographies and reviews for similar music recommendations.
Multi room versatility
For a complete home audio experience, you can update your system wirelessly which allows you to control both servers and Naim streaming products, eliminating the need to manage two separate apps. The NSS 333 is also multi-room compatible with all other Naim streaming products.
High end audio performance
Naim Classic products offer excellent audio quality with tried and tested components. The NSS 333 has a 40-bit floating point SHARC DSP for precise digital sound. Its front panel is easy to use, and the ZigBee remote can control the system without direct visibility. The system automatically goes into standby mode after 20 minutes of inactivity.
300 SERIES
Connections
AirPlay
Bluetooth
Google Cast
Digital Input (Optical)
Internet Radio
Multiroom
Roon Ready
Spotify Connect
Tidal
UPnP™ Streaming
Analogue Input
HDMI Arc
USB
YOUR FOCAL & NAIM SYSTEM
To get the most out of the NSS 333 and enjoy exceptional listening, pair it with speakers from the Utopia range: Maestro, Scala or the Sopra range.
Maestro Utopia Evo
3-way floor-standing speaker
Discover
Scala Utopia Evo
Discover
Sopra N°3
Discover
Similar products
slide 1 to 3 of 3
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
