When formatting an external Store or Back-up drive what file format should I choose?
The file format choice depends on which type of computer operating system computer you use.
NTFS: Windows
HFS+: MAC
EXT: LINUX*
 All these file formats are supported by the Uniti Core, but if plugging the drive directly into another computer, the ability of the computer to read the drive will depend on the file format structure supported.
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
