Product Compatibility Flowcharts - Introduction
These flowcharts cover the vast majority of Naim products from recent years. They do not cover the New Classic 200 and 300 Series, but comprehensively details system compatibility and matching prior to 2023.
These guides are best utilised by downloading the PDFs attached to each article and viewing in a suitable PDF handler, such as Adobe Acrobat. This will enable access to the product page links embedded in the PDF as well as the drop-down information panels, providing details such as required interconnects and product applications.
If you require further information on guidance on compatibility, upgrade paths or inter-product connections, please contact either your Naim Dealer or Naim Technical Support - [email protected]
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
