How do I change my Volume control from a slider to buttons?
The app lets you control volume in two ways:
Slider
Buttons
By default, volume is controlled by the slider, but it's easy to change to buttons.
Changing the volume control between slider or buttons
From the Home Screen of your product, select Settings ()
Select Other Settings
Select Volume control
Make your choice in the pop-up
Note: you may have to reopen the app to see the changed volume control
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
