What’s a Favourite? | A Favourite is any type of music (e.g. Album, track playlist) from almost any source (Tidal, Core, Local music etc) that you want to see on the Home Screen of the Naim product you’re listening to. |
Can anything be a Favourite?
| Nearly. You can Favourite all items found on: Naim server (Core), Naim Server (Atom/Star/Nova/ND5XS, NDX2, ND555), TIDAL, Qobuz and some Spotify content. … but not on: Naim Server (HDX, Uniti Serve), third party UPnP Servers.
What is a Spotify Favourite? | Spotify Favourites are a little different from other streaming Music Favourites. This is a Spotify feature that allows you to recall a 'favourited' Spotify play queue rather than pointing at a specific media item. |
How do I create a Favourite?
| Look for the outlined star icon or 3 dots. Most items in a list (e.g. from a Search) or when selected will have an ‘Options' menu (3 dots) in which you’ll see an ‘Add to Favourites' option with a 'star’ icon.  Once added, the item will always show with a filled star. It can be un-Favourited from the same places.
How do I use my Favourites on my Home Screen?
| All Favourites are displayed under their appropriate tab with the most recently added at the top. The first 10 Favourites are shown, but you can press 'More' to see them all with greater sorting and filtering options.
Can I sort the Favourites on the Home Screen?
| No. They’re arranged with the most recent at the top so you can quickly access the latest music you’ve acquired through Favouriting. Think of it like putting your newest CDs at the top of the pile.
I’ve got loads of Favourites. How can I sort and filter them?
| Opening the Favourites browser (the ‘star' icon) or tapping 'More' at the bottom of a tab on the Home Screen will take you to all your Favourites where you can sort and filter your collection with greater control. Just tap 'A-Z’.
What’s the Home Screen Favourites icon for?
| Tapping the 'star' Favourites icon opens a Favourites browser to give you greater control over all your Favourites. Selecting any category allows you explore your collection via detailed sorting and filtering.
I don't need the Favourites icon, can I hide it? | Yes. Select the ‘Settings' icon (cog wheel at the top right) and then ‘Input Settings’, then 'Favourites’ where you can hide it from the Home Screen. The Favourites functionality is unaffected. |
Will I see my Favourites on all my Naim products? | Yes. Once a Favourite is created, it is available on any Naim product that can play it. For example, you can Favourite a Tidal album whilst listening on your Atom and access it immediately from Favourites on your NDX2. |
