Do mains cables affect performance?
Certainly.
A system is only as strong as its weakest link, and at Naim we believe that system upgrades should always be carried out from the source end first.
With these two tenets in mind, it makes perfect sense to take the quality of the mains supply to your system into account as much as power supplies, interconnects and speaker cables.
While high quality mains cabling is more or less a given with our higher-tier systems, benefits can certainly be heard with our integrated systems. If you're an owner of a Uniti Range product and are seeking an uplift in sound quality, but aren't keen to increase your box count, then the Naim Power-Line is the perfect addition.
The Naim Power-Line consists of a mains outlet plug, a mains cable and a mains IEC inlet plug. All the components are custom designed: the Power-Line is manufactured with 4mm2 cross section, copper conductors, individual dielectric insulation chosen for its sound-enhancing electrical properties and a rubber outer that provides high levels of inherent mechanical damping and the correct stiffness to aid cable dressing. It’s compatible with all mains-powered Naim products.
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
