Can I rename my inputs?
To rename an input enter menu then choose Inputs. Select the required input from the list then choose Name. Now use the handset keys to set the new name is delete if you need to correct a mistake). Once you have finished then OK; to save the new input name.
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
