Can I rename my device on the network?
To change the device name that your UnitiND or NAC-N series product appears as on the network go to the Settings menu (press the spanner on handset) then choose Network settings Name and change the text that is displayed as required using the handheld remote. (Use preset on the remote for delete if required.) When finished press OK On the HDX, UnitiServe or NS0x it is possible to change the devices UPnP, server name. Using the web interface or TV GUI go to and change the device name as required
JOIN THE COMMUNITY
Receive a sneak preview of the latest audio innovations from Focal and Naim by subscribing to our exclusive newsletters. Be among the first to discover our new products, and receive privileged information straight to your inbox.
